MyIntrinsics++ (MIPP)
MIPP MIPP!
Purpose
MIPP is a portable and Open-source wrapper (MIT license) for vector intrinsic functions written in C++11. It works for SSE, AVX and ARM NEON instructions.
MIPP wrapper supports simple/double precision floating-point numbers and also signed integer arithmetic (32-bit, 16-bit and 8-bit).
On ARM NEON instructions the wrapper supports only simple precision floating-point numbers.
With the MIPP wrapper you do not need to write a specific intrinsic code anymore. Just use provided functions and the wrapper will automatically generates the right intrisic calls for your specific architecture.
Download
Click here to get the MIPP files!
Or here is the link to the Git repository.
Documentation
Install and configure your code for MIPP
You don't have to install MIPP because it is a simple C++ header file.
Just include the header into your source files when the wrapper is needed.
#include "MIPP/mipp.h"
mipp.h use a C++ namespace: mipp, if you do not want to prefix all the MIPP calls by mipp:: you can do that:
using namespace mipp;
Before trying to compile, think to tell the compiler what kind of vector instructions you want to use. Remember, MIPP currently supports SSE, AVX and NEON instructions.
For example, if you are using GNU compiler (g++) you simply have to add the -march=native option for SSE and AVX CPUs compatible.
For ARM CPUs with NEON instructions you have to add the -mfpu=neon option (since most of current NEON instructions are not IEEE-754 compatible).
MIPP also use some nice features provided by the C++11 and so we have to add the -std=c++11 flag to compile the code. Your are now ready to run your code with the mipp.h wrapper.
Vector register declaration
Just use the mipp::Reg<T> type.
mipp:Reg<T> r1, r2, r3; // we have declared 3 vector registers
But we do not know the number of elements per registers here. This number of elements can be obtained by calling the mipp::nElReg<T>() function (T is a template parameter, it can be double, float, int, short or signed char type).
for(int i = 0; i < n; i += mipp::nElReg<float>()) {
The register size directly depends on the precision of the data we are working on.
Register load and store instructions
Firstly, register loads or stores need to be aligned on the register size.
To allocate aligned data you can use the mipp predifined vector class: mipp::vector. This class is fully retro-compatible with the standard std::vector class and it can be use everywhere you can use std::vector.
mipp::vector<float> myVector(n);
Now, if the data are correctly allocated we can perform a register loading from the vector:
int n = mipp::nElReg<float>() * 10;
int i = 0;
mipp::Reg<float> r1 = &myVector[i*mipp::nElReg<float>()];
Store can be done with the store(...) method:
int i = 0;
// do something with r1
r1.store(&myVector[(i+1)*mipp::nElReg<float>()]);
Register initialization
You can initialize a vector register from a scalar value:
mipp::Reg<float> r1; // r1 = | unknown | unknown | unknown | unknown |
r1 = 1.0;            // r1 = |    +1.0 |    +1.0 |    +1.0 |    +1.0 |
Or from an initializer list (std::initializer_list):
r1 = {1.0, 2.0, 3.0, 4.0}; // r1 = |    +1.0 |    +2.0 |    +3.0 |    +4.0 |
Computational instructions
Add two vector registers:
mipp::Reg<float> r1, r2, r3;
r2 = 2.0;     // r2 = | +2.0 | +2.0 | +2.0 | +2.0 |
r3 = r1 + r2; // r3 = | +3.0 | +3.0 | +3.0 | +3.0 |
Subtract two vector registers:
r3 = r1 - r2; // r3 = | -1.0 | -1.0 | -1.0 | -1.0 |
Multiply two vector registers:
r3 = r1 * r2; // r3 = | +2.0 | +2.0 | +2.0 | +2.0 |
Divide two vector registers:
r3 = r1 / r2; // r3 = | +0.5 | +0.5 | +0.5 | +0.5 |
Fused multiply and add of three vector registers:
mipp::Reg<float> r1, r2, r3, r4;
r1 = 2.0;                     // r1 = | +2.0 | +2.0 | +2.0 | +2.0 |
r2 = 3.0;                     // r2 = | +3.0 | +3.0 | +3.0 | +3.0 |
r2 = 1.0;                     // r3 = | +1.0 | +1.0 | +1.0 | +1.0 |
// r4 = (r1 * r2) + r3
r4 = mipp::fmadd(r1, r2, r3); // r4 = | +7.0 | +7.0 | +7.0 | +7.0 |
Fused negative multiply and add of three vector registers:
// r4 = -((r1 * r2) + r3)
r4 = mipp::fnmadd(r1, r2, r3); // r4 = | -7.0 | -7.0 | -7.0 | -7.0 |
Square root of a vector register:
mipp::Reg<float> r1, r2;
r1 = 9.0;             // r1 = | +9.0 | +9.0 | +9.0 | +9.0 |
r2 = mipp::sqrt(r1);  // r2 = | +3.0 | +3.0 | +3.0 | +3.0 |
Reciprocal square root of a vector register (be careful: this instrinsic exists only for simple precision floating-point numbers):
r2 = mipp::rsqrt(r1); // r2 = | +0.3 | +0.3 | +0.3 | +0.3 |
Comparisons
Find the minimum between two vector registers:
r3 = mipp::min(r1, r2); // r3 = | +2.0 | +2.0 | +2.0 | +2.0 |
Find the maximum between two vector registers:
r3 = mipp::max(r1, r2); // r3 = | +3.0 | +3.0 | +3.0 | +3.0 |
Permutations
The rot(...) method allows you to perform a rotation (a cyclic permutation) of the elements inside the register:
r1 = {3.0, 2.0, 1.0, 0.0} // r1 = | +3.0 | +2.0 | +1.0 | +0.0 |
r2 = mipp::rot(r1);       // r2 = | +0.0 | +3.0 | +2.0 | +1.0 |
r1 = mipp::rot(r2);       // r1 = | +1.0 | +0.0 | +3.0 | +2.0 |
r2 = mipp::rot(r1);       // r2 = | +2.0 | +1.0 | +0.0 | +3.0 |
r1 = mipp::rot(r2);       // r1 = | +3.0 | +2.0 | +1.0 | +0.0 |
Of course there are many more available instructions in the MIPP wrapper and you can find these instructions in the MIPP files .
Code examples
Addition of two vectors
#include <cstdlib> // rand()
int main()
	// data allocation
	const int n = 32000; // size of the vectors vA, vB, vC
	mipp::vector<float> vA(n); // in
	mipp::vector<float> vB(n); // in
	mipp::vector<float> vC(n); // out
	// data initialization
	for (int i = 0; i < n; i++) vA[i] = rand() % 10;
	for (int i = 0; i < n; i++) vB[i] = rand() % 10;
	// declare 3 vector registers
	mipp::Reg<float> rA, rB, rC;
	// compute rC with the MIPP vectorized functions
	for (int i = 0; i < n; i += mipp::nElReg<float>()) {
		rA = &vA[i];
		rB = &vB[i];
		rC = rA + rB;
		rC.store(&vC[i]);
	return 0;
